CCD MI-6: Performance in less than 7L
Discussion in 'Small Form Factor Systems' started by Firewolfy, Nov 23, 2015.
  1. Frazhna
    Frazhna Limp Gawd
    152
    Jun 27, 2013
    Does your order’s tracking info also say shipment cancelled?
    I tried to contact the seller to find out what is going on, but there has been no response. I’m afraid I’m going to have to go through the refund process.
  2. Engr62
    Engr62 Limp Gawd
    455
    Mar 24, 2015
    It has a tracking number, but it says "tracking information is temporarily unavailable" since the get go. Looks like my first experience with Aliexpress will be my last.
  3. Frazhna
    Frazhna Limp Gawd
    152
    Jun 27, 2013
    I just finished opening a dispute on my order. It doesn’t have an option to refund the shipping cost.
    I’m not going to waste money on Aliexpress again either.
  4. EnzoFX
    EnzoFX [H]ard|Gawd
    1,276
    Apr 21, 2005
    I'd like to recommend ensourced.net. Had some done there and I don't think they could have turned out better. Will have more done there as the builds rolls out. It was cheaper there as well than any other custom place I was able to find. I think it was like $60 for mine. Sure it's significantly more still than those aliexpress ones, but they look significantly better as well.
    Frazhna likes this.
  5. rfarmer
    rfarmer [H]ard|Gawd
    1,125
    May 9, 2014
    Card is probably 2mm too long to fit properly but by pushing the front of the frame over I was able to install it, think I am the first to have RTX in my MI-6. :D
  6. Frazhna
    Frazhna Limp Gawd
    152
    Jun 27, 2013
    Are you trying to reclaim your performance per liter title?:)
    rfarmer likes this.
  7. rfarmer
    rfarmer [H]ard|Gawd
    1,125
    May 9, 2014
    I wish, this would help but there are a couple builds on there I would need a lot more than a 2070. It is a performance boost though, I went from 15246 to 18340 in Firestrike and 5985 to 8052 in Timespy.
    Frazhna likes this.
  8. EnzoFX
    EnzoFX [H]ard|Gawd
    1,276
    Apr 21, 2005
    I myself am looking for an MSI aero itx card, 1070? Don't think there are TI's. Case will be here soon!
  9. Firewolfy
    Firewolfy Gawd
    571
    Sep 11, 2015
    It's happening. 20 cases shipped today......
    I'll be shipping every few days, and should have everyone's out within a week.
    octagoncow, Frazhna, Boil and 2 others like this.
  10. Frazhna
    Frazhna Limp Gawd
    152
    Jun 27, 2013
    E381D905-A62E-4EB0-8804-90CD037E2415.jpeg 79E240D1-0288-4830-B1E3-EE7E30B18449.jpeg I love it! Video card isn’t thermally throttling anymore, like it did in my old case. At Idle, I can’t hear a thing over the ambient sounds of my apartment, and the Noctua 92x14 is the most audible at load (I don’t hear it because it only ramps up when I’m playing games)
    Too bad I didn’t get those custom cables.
    It was pretty hard to smash those stif stock cables in there.
    Firewolfy and rfarmer like this.
  11. EnzoFX
    EnzoFX [H]ard|Gawd
    1,276
    Apr 21, 2005
    I can't decide between the nh-l12 or the nh-l9a-am4.
    I'd probably go with a 65w cpu, but I'm thinking pure aesthetics Haha. Always been a proponent of fitting the biggest cooler and fan possible, however this tiny thing is almost pushing me to go a different route. As if to showcase more detail. Maybe more potential mods. Had a great experience with the nh-l9i.
    Oh man this builds gonna take me a while.
  12. Firewolfy
    Firewolfy Gawd
    571
    Sep 11, 2015
    Great job! Glad to see all 3 drive spots being used, but that does mean a lot of sata cables.
    I put some of my excess cabling over on top of the psu, on the gpu side. You might try that.
  13. Frazhna
    Frazhna Limp Gawd
    152
    Jun 27, 2013
    I was thinking that there is a lot of unused space on the GPU side, but by that time, I already had a sata cable going under instead of over. My biggest difficulty was the sata power cables that came with my power supply. The connectors are just too fat to fit the drives that are right next to eachother, So I ended up using the molex power cable and molex to sata adapters because they were so much more thin. I might give this a re-work some time soon. I keep thinking that I want to try sticking a 4th drive in there next to the one on the bottom. If I do it, I will probably have to be stuck in there with double sided tape.
    also, apologies for the terrible photos, I'm not very good with cameras
    edit: I updated my signature line to reflect my new hardware :)
  14. rfarmer
    rfarmer [H]ard|Gawd
    1,125
    May 9, 2014
    I see you went with the white Prolimatech fan on your SBS2, looks good.
  15. Frazhna
    Frazhna Limp Gawd
    152
    Jun 27, 2013
    The white version seems to be hard to come by. It even cost a few dollars more than the black, but I liked the look and I was planning on matching it with white PSU cables (until the AliExpress order fell through). Thanks for the recommendation on that fan, it’s so quiet I never hear it.
    I just finished a 3 hour video game session and my graphics card never thermally throttled and my overclocked CPU was just fine too. This setup is working great!
    GermanDrifter97 likes this.
  16. rfarmer
    rfarmer [H]ard|Gawd
    1,125
    May 9, 2014
    I never even saw the white when I was shopping for them, looks good. I feel bad about recommending AliExpress now, other than slow shipping I didn't have any problems with either of my orders. Too bad they weren't able to deliver, makes the build so much easier. Glad to hear your GPU is performing well.
  17. rfarmer
    rfarmer [H]ard|Gawd
    1,125
    May 9, 2014
    Gigabyte RTX 2070 now up for sale on Newegg.
    GermanDrifter97 and Firewolfy like this.
  18. GermanDrifter97
    GermanDrifter97 n00b
    41
    Jan 6, 2017
    This looks so tight! Nice fit. Guess that spices things up a bit in the PPL thread ;)
    I ordered some custom PSU-cables which arrived yesterday. Already built them in and took some fotos, gonna post a little update ASAP.
    rfarmer likes this.
  19. GermanDrifter97
    41
    Jan 6, 2017
    So I want to post a little update on my MI-6 build.
    Next to HDD space and a more decent CPU-cooler, I wanted to upgrade the PSU cables for 1) a better visual look of the system (if it is opened, you don't see anything with the side panel on lol) and 2) better air circulation. The old silverstone cables that came with my SX800-LTI were way too long and clumsy, and as I'm far from an expert in cable management, the case looked very cramped with cables.
    I looked at different options for custom sleeved PSU-cables, but they were either too expensive (over 120€ on cablemod) or the shortest option for cables was still to long.
    In the end, I found someone who takes orders for custom cables here in Germany, and he kindly helped me in finding the right length and other things so the cables would fit perfectly into the case.
    And I think the results can speak for themselves:
    The mainboard compartment
    The GPU cable
    The custom SATA-power cable
    In the last pic you can see what a tight fit the 24-Pin Mainboard cable is, as it has to be bent in a S-curve. Actually, I wanted to mount a third harddrive with the HDD-mounting-bracket next to the PSU, so I hope that won't be a problem.
    Also, the custom SATA-cable is a bit too short between the two connectors at the top. I had to remove the lower screw of the second HDD, so it is slightly angled to fit into the power connector. Not 100% perfect, but as close as it gets.
    If I had to order custom cables for the MI-6 again, I honestly would think twice about sleeving them. Sure, it looks way better than "naked" cables, but as there is no window-option for the MI-6, and as the sleeved cables are way harder to bent than normal ones, it might be enough just to order them in custom lengths without the sleeving.
    rfarmer likes this.
  20. rfarmer
    rfarmer [H]ard|Gawd
    1,125
    May 9, 2014
    Cables look great, what lengths did you go with. It's too bad that double SATA power connector is a bit too close together, that looks great.
  21. GermanDrifter97
    41
    Jan 6, 2017
    The 24-Pin Connector is 200mm
    The 4+4 Pin EPS Connector is 250mm
    The 8-Pin PCIe is 300mm
    And the SATA is PSU -- 100mm --> SATA -- 150mm --> SATA -- 3mm --> Sata
    I was very surprised when I asked him this. First, I wanted to go with a 50mm cable between them so that I could put a little loop between the two HDDs. I asked him what the minimum distance between the two connectors is so he can still work properly, and he just said "as close as the two connectors can get to each other". So I measured the exact distance between the two drives, and from my calculations the cable length should be 3mm at that point. I guess he made them a bit too short, bit it still works very well.
    rfarmer likes this.
  22. EnzoFX
    EnzoFX [H]ard|Gawd
    1,276
    Apr 21, 2005
    For some reason I thought the am4 stock cooler didn't fit. Hmm, still may go with the noctua but glad to see it does!
  23. GermanDrifter97
    41
    Jan 6, 2017
    It does, but I had to remove the upper plastic shroud around the fan (the one with the AMD Logo in it). The big advantage of doing so is that the LED-ring now iluminates the whole motherboard-side of the case, giving it a nice RGB shine. :)
    rfarmer likes this.
  24. Firewolfy
    Firewolfy Gawd
    571
    Sep 11, 2015
    Batch Update--
    Shipping Started Jan 7.
    As of Jan 14, 29 cases have shipped, 19 to go. All should be out by Jan 17, unfortunately ti's a few days later than planned.
    Tracking info emailed automatically.
    -Fire
  25. Firewolfy
    Firewolfy Gawd
    571
    Sep 11, 2015
    Batch update--
    Looks like finishing and shipping the last 19 cases will take a few more days. Got feedback from my fab shop that they need a few more days to remake some chassis'.
    I found a problem last week with the bends on some chassis', and they have been re-making them from scratch. They targeted getting them to me by the start of this week, but the date has slipped. They are busy with higher-volume work, and my small batch has to wait sometimes.
    I will update as I find out more.
  26. Firewolfy
    Firewolfy Gawd
    571
    Sep 11, 2015
    Batch done.
    Got the rest of the case parts Friday, and then assembled over the weekend and shipped this morning! Everyone should at least have a tracking number before the end of today.
    Went smoother than the first batch last year, so that was great!
    On to the lofts, and maybe I need a 2060 (!)
    -Fire
  27. rfarmer
    rfarmer [H]ard|Gawd
    1,125
    May 9, 2014
    No you need a 2070. ;)
  28. Firewolfy
    Firewolfy Gawd
    571
    Sep 11, 2015
    Well,
    Somehow email alerts didn't happen for over 50% of the shipments. The USPS shipping website has been having problems, so maybe that was one of them. I sent out tracking numbers to everyone who is still waiting for delivery. Sorry about that guys, really stinks to wait and be in the dark.
    Fred
  29. Frazhna
    Frazhna Limp Gawd
    152
    Jun 27, 2013
    One of my biggest concerns before I got this case was CPU cooling. I was afraid that I would have to lose my overclock, but after using it for the past few weeks, I’m pleased to report that I can keep my overclock. The scythe big shuriken II has been keeping my i7 4770K (overclocked to 4.5GHz) in the sub-60° range while gaming.
    I also made a recent change to the fan curve of the case fan so that I can’t hear it anymore and the temps are still great. Last night after playing games for a couple hours, my gpu was averaging 74° and CPU was averaging 57°!
    I was super excited about these temps, then I remembere that my apartment has been pretty chilly lately because of the weather. Even with the colder apartment though, I think it is much better off than my old case. Once my apartment heats up again, I’ll have to check on my temps again. (My stupid radiator heated apartment complex doesn’t let me control the heat, so I’m cold, but my computer is happy.)
  30. rfarmer
    rfarmer [H]ard|Gawd
    1,125
    May 9, 2014
    Good to hear, glad the BS2 is working out well for you. I was really worried about cooling my 8700k, even delidded with the BS2, but it works really well.
  31. GermanDrifter97
    41
    Jan 6, 2017
    What temps do you get rfarmer? I am still looking for a good alternative to my Wraith spire, it can get a bit loud, and the 92mm fan is just too small to keep other mainboard components cool.
  32. Engr62
    Engr62 Limp Gawd
    455
    Mar 24, 2015
    The Big Shuriken 2 Rev. B cooler doesn't have AM4 support.
    rfarmer likes this.
  33. GermanDrifter97
    41
    Jan 6, 2017
    Frazhna, Jspr, Engr62 and 2 others like this.
  34. rfarmer
    rfarmer [H]ard|Gawd
    1,125
    May 9, 2014
    Decided to retest last night since I hadn't run any stress tests for almost a year. Prime 95 Small FFT s, 4.30 GHz at 1.15v and ambient about 22C. Highest single core was 69C. So even after 1 year the BS2 is still doing a really good job cooling my 8700k.
  35. Frazhna
    Frazhna Limp Gawd
    152
    Jun 27, 2013
    Got my 4th drive in my MI-6!
    I screwed some drive spacer brackets on over the drive cage and was able to attach another drive in the lower spot.
  36. Firewolfy
    Firewolfy Gawd
    571
    Sep 11, 2015
  37. rfarmer
    rfarmer [H]ard|Gawd
    1,125
    May 9, 2014
    Anyone looking for a MI-6 check out my sale thread over on SFF.
