Boil
- Sep 19, 2015
Yes, it should be fine, on the upper location. I might add a mm or 2 to be sure, depending on how the tolerances stack up.
Won't fit down at the lower front location, though, because the MB and divider are close and the HDD/SSD can't be pivoted out of the spring clip. It has to be hard mounted down there.
The top mount would be just fine, using the spring clip would allow me to place the heat sink fins to the inside of the chassis, and also allow the proper vertical orientation of said fins for best airflow/cooling from the bottom-mounted Noctua NF-A8 PWM 80mm chassis fan…
Also, I just found out I am the LUCKY WINNER of the smallformfactor.net Corsair SF600 SFX PSU giveaway; so, YAY…!!! I now have an AWESOME PSU for my MI-6 build…!!!
