Boil
- Sep 19, 2015
Jen,
Thx for the feedback. Well I don't have much in the way of tools either, LOL. All I have is a new sheet metal brake for simple bends. Everything else is outsourced.
yes same here basic sheetmetal benders , some grinders , welders , sanders and drill press . with health issues and breaking my ankle i havent been able to do much . just watching threads like this inspires me to keep trying to get better and try new ideas in the future
you are very talented in your designing of this case .
Got this SF600 PSU still sitting here, waiting for a home…
But I would like to ask about adding the ability to mount dual NF-A9x14 fans up top for exhaust again…?!?
With the (optional) "no front i/o" faceplate (meaning I could use the lower front mount for a second Intel 750 Series 2.5" (x15mm) SSD…
Because I just realized the Asus Strix Z270 ITX MB has PCIe 3.0 x4 to both of its M.2 slots, AND it will allow configuring for RAID across the M.2 slots…!
... overall width of the chassis is dictated by the width of the SFX PSU…
Well, there would be room if the 3.5 is in place of the gpu. I looked at this last month and tried doing some geometric magic, the 3.5 is huge in this case. The only way is if a discrete gpu isnt needed.I don't see a need for the top fans either. I'm hoping that this can be as small as possible while still retaining a SFX PSU. The only thing I would hope is that we could find a way to integrate a 3.5inch HD for those of us who need a ton of bulk storage but don't want to use an external HD.
Hmmm. Well, I appreciate the effort. No worries then. I still plan to get one even with just multiple 2.5 mounts. Next question I guess is have you considered beveling the front panel like the NCASE M1? You could probably sneak one or two 2.5 inch drives behind it if you did. Also, with the bottom intake fan, could you test the temps with the side panel intakes blocked off as if it were tempered glass on either side?
Also the front USB ports, if you could make them black instead of blue....
Below is an update I posted last night over at sff. I'm copying it here for those who don't surf that forum, --and to make my life a little easier not having to type another post (!)
Ok, I have an update, woo hoo! Got back the 2 powdercoated covers. I also got couple front plates PC'd too to see how they would look.
I also got a 3d printed power button this evening. My buddy printed it in green rather than black, so the features are easier to see and check. The button has a thin center circle that allows the power led to shine thru. The production intent is translucent black.
So here is the gloss textured front plate, semigloss textured cover, and the power button. (That's a Noctua 92mm HS on the CPU that looks so tiny.)
And here is a pic with the power off --
I think the front texture is a bit too big and glossy. I'll get the other front plate on tomorrow and post a pic of that.
Thx
It looks awesome!
If I looked right you have a Noctua Cooler inside? How much space is between the fan and the sidecover?
ok, so a Wraith cooler should have more than enough space. Thanks for the shematic!
Hmm, I don't have a wraith to check, but I'm reading that it is 80 or 84 mm tall. That would be too tall, unless there are now more than 1 version of the wraith....
Thanks man!Case looks awesome! I really like the look. Good luck
Sam-1997 -- That isn't a bad looking case and very solid, that's for sure. Thick 5 or 6mm alum plate, wow.
It is wider and deeper than the MI-6, but looks like a 65mm cpu cooler might not fit because the case is so thick.
No bends to worry about, just a Lot of threading. Sweet design for someone who had a mill at home.
thanks
There are several computer cases in China
Mostly with thicker aluminum
With the use of CNC precision higher precision processing better
Also can be customized for their own convenience
Your chassis is more fine like branded products
Look forward to your product listing
Thanks for thought out reply.
Yeah i saw that picture in previous pages, and from my experience in small builds, if you block that bottom vent, you'll have serious heat issues. But seeing the actual bottom, i see you can say its vent only w/o having to change anything after testing final prototype. On that note, besides switching to SFX from ATX, i used the Silverstone ATX to SFX PP08 bracket which is vented instead of solid plate(Generically its Kingwin KWI-SA-08). I can feel heat coming out of there. I think even with your design, the little area under power button, along MB rear ports should be as vented as possible. Which i saw in previous renders. Something to consider. Same for little space under GPU slot.
About the PSU on top, i see now you cant really flip case due to GPU mounting. But i am really curious about having the PSU above GPU/MB. In actual fine print/usage, almost all silent/passive PSUs have note that the optimal/expected condition is that either case fans help with a little air flow or it is sitting open vent up to allow convection. Granted my i3-6300+GTX 1060 6GB + (6x7mm) 2xSSD+4xHDD isn't a lot, even pushing Prime and GPU and disks at same time wasn't enough to bring fan on. At same time, I've never had the PSU be even more than maybe warm to touch the way its mounted in Sugo SG13. Im just curious if you've done any modeling to rule out that configuration for folks wanting to use passive PSUs.
And you're right, i double checked and i was visualizing my m.2 layout wrong. It is along/near PCI-E slot/chipset, as you said is most common.
Anyway, really like your case, wanted to help if i could. I really like that front plate idea. Besides artsy plexiglass designs, I expect folks will mod with card readers, front panel IO ripped out of old case(or ebay) or just a jerry-rigged hub if they really want it, and of course someone will fit a slot loading blu-ray laptop drive... I do think if the panel behind front plate is clean enough, just shipping with the four screws would save you some costs for use elsewhere, would be viable. As most would likely get some plexiglass acrylic plate to work with instead of metal.
hi i like to pre order MI-6 =) is it to late?
Micke from sweden
