Any cooler 65mm tall or less will fit.What would be the best cpu cooler for this case?
I putting together some graphics/brochure type material. I added what I have so far to the first page. Enjoy!
…68mm in height, which puts it at the threshold of CPU cooler clearance.
The CPU cooler clearance on the MI-6 is 65mm, so the unit you reference is 3mm too tall…
The included fan (review linked does not specify the thickness of the fan) appears to already be a "slim" model, so no hope of fitting a different fan to try & get at or under the 65mm clearance threshold…
Best bet, IMHO, is the Noctua NH-L9x65; maximum height allowed & virtually zero interference issues with MB components…
Second test: the Noctua NH-L9x65 cpu cooler!
It fit in the the case with about 2mm to spare to the outer wall, so that was about as expected.
Firewolfy,
Question(s) about the Gigabyte GTX 1070 Mini…
Spacing between GPU & inside of outer shell…?
Thickness of shroud…?
Estimated spacing between heat sink & inside of outer shell (with shroud removed)…?
It is my understanding that the fan connection on the 1070 Mini is a 4-pin PWM, so pulling the shroud & using a larger fan might improve temps & airflow…?
I imagine the heat sink from the Noctua NH-L9x65 on the CPU side, the stock heat sink included with the 1070 Mini on the GPU side; and a Cryorig XT140 slim (13mm) fan on either side, feeding air into each chamber…
I am torn between going with an i5 6500 & the EVGA GTX 1060 SC; or stepping up to an i7 6700 & the Gigabyte GTX 1070 Mini OC…
I would save 260 bucks with the former setup, but might be a bit more future-proof with the latter setup…?
I think I am leaning towards the i7 6700 paired with the EVGA GTX 1060 SC; that way I have three DisplayPort connections for a triple-monitor setup down the road…
Click on the username, pick "start at new conversation"I would have liked to preorder but I must have a too low rank on the forum. I can't find any "Send Private Message" link anywhere.
Sorry about the lack of updates recently, let's get to it!
So, I got reasonable pricing from the new machine shop I have been working with on quoting. Specifically we were working on a run of 30pcs.
A couple bits to be resolved--
1) I need to discuss what he needs to make a couple prototypes to verify dimensions and fit and finish. I have not heard back yet on that. That is a concern of course, and as I mentioned previously, I need to figure out how to fund that.
2) Recently I have been given the opportunity to find a new job. So, unfortunately for the Mi-6 timing, I am spending a lot of time working on that. As I get back on my feet, hopefully in the next few weeks, I can jump back into getting some beauties made!
Would the use of a shroud on the cpu cooler fan (let's say on the x65) to seal intake to outside only help with temperatures?
Have you considered testing the 92mm intake fan with a spacer/shroud? It could provide a little bit more air and help with pressure.
Interesting CPU coolers that may be worth a look:
- Zalman Quiet
Since this cooler has somewhat of an radial spread, it could help with air circulation.
- Thermaltake Engine 27
A japanese review indikates bad performance, but amazon reviews tell a better story.
- Thermalright AXP-100H Muscle
Seems to make cable management easy to do.
-- A quick note -- Looks like I'll be working this project more now, as it's pretty sure I've landed a new primary job, yeah!
