It was just released on AMD's website:
http://sites.amd.com/us/game/downloads/Pages/downloads.aspx
Release Notes link no worky...
hm
Random mouse cursor corruption is no longer seen
Powerplay isn't working correctly with overdrive settings... oh well.
so they have a 10.12 preview driver available which is essentially a beta?
When Overdrive is enabled, 2D memory clock speeds are no longer affected by custom memory clock speeds. Finally, my 4850 can idle 10C lower, haha.
Just installed the 10.12 drivers from AMD's website. Where's the Morphological AA toggle? I can't seem to find it.
Hmm, seems they will have to be hacked for MLAA on my 5870 AGAIN... sigh...
The new interface is... i dunno... .. hmm... White, I guess. Really white.
*shrug*
Y.
They forced your memory to run at full 3D clockspeeds in order to fix screen flickering while changing PowerPlay modes. If the memory clock is changed, the image on all but the primary display flickers for a moment while the RAM stabilizes at the new clockspeed. The only solution was to never change memory clocks, which meant keeping them in the highest performance mode at all times.Exactly, finally i can use my 300/500MHz setting for my 5870 again. I was still on 10.4 because those were the latest drivers supporting this (10.5-10.11 force me to 300/1200).
Ok I just tried these but I can't find the MLAA option anywhere. I'm running the 10.12 preview with the new interface. I'm still using 5000 series but I've been using the 10.4 drivers for months. What driver(s) will give me the MLAA option?
btw, anyone who installs over top of the 10.11 betas, make sure you reset to factory defaults in CCC.
I was having the 2d clock issues on my 5870 with dual monitors until I did that
As I suspected, these are compleatly broken out-of-the-box. Do not install unless you want headaches.
1. They've brought back the old PowerPlay issues. My HD5850 dropped to 157MHz core and 300MHz RAM. My secondary monitors are flickering like crazy because of this. Only solution is to compleatly disable overclocking, the drivers will then idle at the correct clockspeeds (400MHz core / 1000MHz RAM in my case).
2. The PowerPlay issues with Flash video and other forms of DXVA accelerated video are also still present. The video card gets stuck at 400MHz core, 900MHz RAM, and will not enter 3D clocks unless the video is closed compleatly.
3. They've enabled some hidiously bad video "enhancements" in CCC. Turn them all off and set Dynamic Range to "0-255" to drastically improve video quality...
4. OpenGL issues persist. You still have to use atioglxx.dll from Catalyst 10.4 to play older OpenGL titles.
Will we ever get a driver that works right? These are even more broken than 10.10 and 10.11, and they're brining back bugs from EVEN OLDER drivers...
+1Powerplay isn't working correctly with overdrive settings... oh well.
edit: finally, though, haha:
Since the old PowerPlay setup scaled clockspeeds up and down all the time, this lead to a LOT of random flickering. If they've stopped locking memory clockspeed at 3D clocks again, then they've reintroduced that old bug again...
Downloading the drivers now to verify this.
So you're using a second video card for your second display to avoid the flickering caused on secondary display heads by changing memory clockspeeds? That sounds more broken than simply keeping your video RAM at 1200MHz at all times (which is the behavior AMD intends).
