Hey guys,
So my Thermaltake Aguila case (mid tower) is way too full of hardware right now:
GTX 260 Core 216 (long as hell)
3 SATA hdd
2 SATA optical drives
x-fi pci card
wifi pci card
swiftech micro-res
swiftech 655b pump
various fans for cooling
watercooling tubes (just the q6700 cooled right now)
I'd like to get a full tower case (ala Antec 1200/Thermaltake Armor/Cosmos/Stacker 830) that has alot more room in it ..mostly for air flow and space for cable management. The radiator right now is is mounted on the back of the case...like so:
Do any of these or other full tower cases have space for a 3x120mm rad inside somewhere? Or is that just too big?
I had to drill 2 holes in the current case to run the in/out tubing to the rad and use the radbox accessory to mount the rad on the back of the case.
I'm willing to spend ...max $200 on a case (hopefully less, since I'll need to get more water cooling stuff...and maybe a new modular psu for better cable management).
So if you guys could suggest some cases that'd be great. Thanks!
3 SATA hdd
x-fi pci card
wifi pci card
swiftech micro-res
swiftech 655b pump
