case similar to Lian Li PC-A70B?
Discussion in 'Cases & Case Modding' started by polonyc2, Aug 17, 2018.
  1. polonyc2
    polonyc2 [H]ardForum Junkie
    15,111
    Oct 25, 2004
    I've always been a fan of Lian-Li cases (full towers)....great airflow with multiple fan options including top fans, very easy to work with, all aluminum quality and I love their simplistic design...do they even still make cases?...any ones similar to my current PC-A70B out there? (must be full tower)
  2. DoubleTap
    DoubleTap [H]ard|Gawd
    1,866
    Dec 16, 2010
    That is a really old design and cases have changed a lot in the past 10 or so years.
    Bigger fans, simplified interiors and fewer 5.25" drive bays (often zero)
    If you need help choosing a case, describe your needs and expectations and I'm sure you will get many suggestions but we are several generations beyond that old thing :)
    Personnally, I've been considering another tower case:
    Phanteks Evolve X (releases in 2 weeks)
    Cougar Panzer Max
    Fractal Design Meshify C
    Coolermaster Cosmos 700m (no release date)
    The worst trend in modern cases is that intake fans are choked off behind a tempered glass fascia to make a pretty RGB light show while your CPU overheats....
  3. polonyc2
    15,111
    Oct 25, 2004
    I don't like the trend toward blinged out cases with lots of flashing lights and open windows...I want a closed case, preferably black brushed aluminum with good cooling, no neon lights on the outside, preferably full tower...they are really moving away from 5.25" drive bays?...why?...people prefer external DVD-RW drives?...I also have a fan controller that sits in one of those bays...
  4. DoubleTap
    1,866
    Dec 16, 2010
    It's hard to find aluminum cases these days, most companies are using steel and tempered glass.
    Caselabs was a company that made all aluminum cases, but they just went under.
    Lian Li still makes some, I think, but you'd have to look through their website. Their offerings always seem haphazard.
    Jonesbo and I think Raijintek might also have aluminum cases and you can still find some super premium cases in that material.
    If you just want a functional case with some bays and no lights, they exist, you just have to look a little.
    Thermaltake, Silverstone, Fractal Design, Phanteks and NZXT all make cases that might work for you.
    The Fractal Design R6 is an understated, well layed out, modern case with tons of modern features and no RGB - and it has 1 bay.
    Most modern motherboards have enough PWM headers for an air cooled system - I have 6 Noctua fans all controlled by my mATX board.
    If you need more than that, there internal controllers that don't require a drive bay - but if you just like to turn the knobs, then I guess that won't work for you....
  5. Blue Fox
    Blue Fox [H]ardForum Junkie
    11,634
    Jun 9, 2004
    People prefer no optical drives and PWM fans. There's little use for 5.25" bays these days. Few need more than a couple 3.5" bays either.
  6. polonyc2
    15,111
    Oct 25, 2004
    why?...is it a cost issue?
  7. DoubleTap
    1,866
    Dec 16, 2010
    Not sure it's a cost issue, it's just that styles and tastes have changed - just like tail fins and white walls came and went.
    There is a lot of variety in the market and certainly something for everyone.
    I like the Hardware Canucks youtube channel as they regularly do ~10 minute reviews of cases and are not shy about pointing out issues. They have a pretty deep back library of case reviews,
    https://www.youtube.com/user/HardwareCanucks
    pendragon1 likes this.
  8. polonyc2
    15,111
    Oct 25, 2004
  9. pendragon1
    pendragon1 [H]ardForum Junkie
    11,396
    Oct 7, 2000
    the a75 doesn't have the door but is out of stock. the door is also removable...
  10. kamxam
    kamxam [H]ard|Gawd
    1,337
    Mar 2, 2005
    I love my Lian Li V2000, but recently decided to upgrade the case and my system after about 4 years. (Been using the case since they came out however) It's similar to yours somewhat but is an older case. It is a full tower. And may be hard to find nowadays unless on Ebay or such.
    In my case, (No pun intended) i decided to go with the LL PC-07SX case for my new build, which IS great looking imho but expensive. Have to splurge sometimes though :)
  11. IdentityCrisis
    IdentityCrisis [H]Lite
    104
    Oct 29, 2012
    Way back when I had a Lian Li PC-G70 I wish I still had it, I miss it. Had several systems in it, looked sort of like the one you're looking for but no venting in the middle and it was a massive full tower.
