Juggalo23451
- May 2, 2011
CPU MAG CASE MOd WInner
http://www.computerpoweruser.com/DigitalEditions/Default.aspx
pgs44-45
http://www.youtube.com/watch?v=qIb_iHH1jqM
http://www.youtube.com/watch?v=eGrmeWTmOc0
This case is definitely massive can fit 4 480 rads internally. You could fit a 480 rad in the front and a 360 or another 480 in the front. Build quality is exceptional. Packaging for the case was very detailed. It took me about 20 min or so to remove this protective film on the case.
Specs of build
Evga 4 way classified
Intel 970 ordered
2 gtx590s
Muskin ram 6-12gig
2tb wd caviar black
ssd 128 crucial c300
psu 1500 silverstone
Water cooling
primochill Orange 1/2x 3/4 tubing
enzotech compression fittings 1/2x3/4
2 MCP35X pump
Koolance 402x2 reservoir - run pumps in series
White HK
Koolance water blocks
Koolance sli adapter
2 RX 480 rads
1850 Gentle typhoons pull
ek 4 way classified water block
loop order will go
res-pump-rad-gpu-gpu-rad-cpu-chipset-res
Reason I have the chipset last is because it has the most restriction
pgs44-45
Specs of build
Intel 970 ordered
2 gtx590s
Muskin ram 6-12gig
2tb wd caviar black
Water cooling
2 MCP35X pump
White HK
2 RX 480 rads
loop order will go
