Under the BIOS power settings.
Make sure ACPI is enabled with the correct drivers and that the Suspend To mode is set to S3.
That did the trick.
It was set to "S1 & S3" mode.
The only weird thing is that it doesn't wake from the mouse, only the power button.
Under the boot menu in the BIOS, there should be an ACPM (sp?) menu that left you choose how to boot your computer. Not sure if it works for USB mouse, but if you use a PS/2 keyboard, you can make the computer boot with a simple spacebar keystroke.
