eHume tested a three fans on this D15S review here:
http://www.overclockers.com/noctua-nh-d15s-heatsink-review/ (scroll to the very bottom, see the image marked 'second mount')
At 'normal' RPMs, e.g. 1200, there is no benefit. He did not test at lower speeds unfortunately.
However, since you don't have a bottom intake installed anyway, I think the third front intake is a no-brainer.
Note that unless you have a shorter PSU, you normally can only fit a 120mm in the bottom intake. That eVGA ACX card does really benefit from a direct intake though, so food for thought if you have a 120mm lying around.
