Car seat as a chair / Audi A8 Seat
ironforge
Best chair to use, if you are going for a racing sim. Get you the steering wheel/gear shift/pedal combo.. maybe three monitors for surround.. now to check for used ferarri chair on craigslist.
radziu797
Hello, i would like to do the same as you :) But can You tell me when i put only 12v to seat it will be working electric change position from buttons on the seat?? Can you give me your adress email or please writhe here how you do colling and heating to working??? Thanks and Greetings from Poland
Liver
Today OP was a real cool guy. Two year old thread, and excellent follow up.
Thanks and great work.
Awesome project...
to be honest, I was not able to make heat and ventilation works as it should, you need a module to make it works, beside that, if you buy a seat from A5 you just need to wire two wires ( + and - ) and you are ready to go
