Car PC help for highend audio build..
Copyright
I have been playing around with Raspberry Pi 3 car pc setup and like it a lot. I am thinking of doing a windows based setup since it will be faster and have sleep functions as well as more software options.... I have some questions..
It needs to be compact so which mobo/CPU combo? Cant be slow!
I need a power supply that produces CLEAN power.
Is there an APP for car use that will full screen on 7" and be easy to view?
SamirD
One thing you could use besides a NUC would be a thin client and run linux. There's a couple of av builds specifically for htpc type of applications. Couple that with some sort of touchscreen interface on the 7" (if it doesn't already have it) and I think you have a solid solution.
Otherwise, integrating a tablet is something else I've seen done commonly.
