Cant view netowrk conections after sp2 on xp
the-one1
I cant view the network connections folders via properties after i installed sp2.
Any ideas? Need more info to diagnose me?
thnx
valve1138
Sounds like the built in firewall got turned on for the NIC. Don't you love it when Service Packs do "helpful" things!
Go to the Properties Panel and then the Advanced Tab, the Firewall checkbox is probably checked.
