I'm connecting my Samsung 37" 1080p HDTV to my GTX 480 rig.
I have two cables - a VGA-DVI adapter cable and an HDMI to DVI adapter cable.
With the VGA-DVI, it detects the native resolution as 1024x768 (it's not!), but I can easily customize a resolution of 1920x1080/60 and it works perfectly.
The problem is, no game will see the customized resolution and if I edit the .ini file, it simply won't work - this is true for 3DMark, Crysis, Heaven 2.5, etc.
With the HDMI-DVI, it detects 1920x1080 as the native resolution, but when it is applied, it's all screwed up. First of all, the colors are completely out of wack, way too vibrant, probably because of the RGB (can't set otherwise!). Secondly, it's not centered properly. 5% of the resolution is off screen (like it's too big). I can fix this in NCP though.
So, really, I am stuck here. Every other card can output 1080p with the VGA-DVI cable, but apparently not the GTX 480s..
EDIT: I managed to find an HDMI - Mini HDMI cable. It's better than the HDMI-DVI, but there is one big problem - the screen has a ghostly blue-ish hue to it. Definitely not right. Can't change it.
So now what? No VGA, no DVI, no HDMI.. the only thing left is DVI to DVI, but the TV does not have DVI!
ARGH!
ARGH!
