My daughters PC has gone into a perpetual sleep mode, even with hard power button off/on, completely unplugging the PC and waiting etc. It simply turns on into sleep mode and nothing will wake it. I'm not there so I'm having to get youngsters to mess with the hardware. This is a Win 7 PC with wireless mouse and wired USB KB. I've already tried to remove and replace the wireless mouse receiver into a different USB port to no avail.
How the heck does it stay in sleep mode without power!?! If I was there I'd pull the button battery as well to reset BIOS.
Supposedly this is WIN 7's fault with some setting. Once I get back control, I can try this hopefully
This is probably due to the Wake Timers. Wake Timers are a component that programmers can use to wake an idle system and peform a routine function.
Prior to Windows 7, the user had no control over this.
Windows 7 gives the user the option to disable or enable the sleep timers.
If you wish to change this setting.
Open Control Panel.
Select the All Control Panel Items option.
Select Power Options.
Click Change plan settings in the selected plan.
Click Change Advanced Power Settings.
Click the + sign next to Sleep.
Click the + sign next to Allow Wake Timers.
Select the Disable option.
Click Apply / OK.
