Title says it all. I can't for the life of me get my Q6600 above 3.00GHz IBTv2.4 Maximum stable.
Components:
GIGABYTE GA-EP45T-UD3LR Rev1.0 with latest (F5) BIOS
Intel Q6600 B3 VID 1.3125
GeIL 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1333
Enermax Galaxy Evo 1250w
Prolimatech Megahalems Rev. B with 2x Yate Loons Mediums in Push/Pull.
Termalright HR-05/IFX + Panaflow 80mm fan
Temps are 23c-24c idle and 56c-57c load @ 23.2c ambient
here are my settings:
It won't even do 3.06GHz let alone 3.1, 3.2, or 3.3 :/
It's obviously not the power supply. The RAM goes up to at least 1522MHz if I loosen the timings (passes 12 passes of memtest86+). I think the motherboard just sucks. It can't do 400BCLK, but I really don't need it to. I'd be really happy with a 3.2GHz overclock which is 9x355 but I can't seem to do anything to make it work.
I've tried upping the voltage way past what is needed (1.45v) as well as bumping the CPU Termination to 1.4v and the PLL to 1.750v (which I got from an anandtech article on OCing a Q6600) and the MCH Core to 1.4v. Everything I do is met with a BSOD as soon as IBT ramps up to 100% all cores.
Is it the motherboard? Can the chip just not do it? fucked up northbridge?
Any help would be much appreciated.
Components:
Code:
CPU BClock and Multi: 333x9
MCH Frequency Latch: 333MHz
System Memory Multiplier: 4.00B
MEMORY (All these settings are the JEDEC specs)
Cas Latency Time: 7
tRCD: 7
tRP: 7
tRAS: 24
tRRD: 4
tWTR: 5
tWR: 10
tRFC: 60
tRTP: 5
CMD: 2
VOLTAGES
CPU Vcore: 1.35625v
CPU Termination 1.200v
CPU PLL: 1.550v
CPU Reference 0.805v
MCH Core: 1.100v
MCH Reference: 0.760v
ICH I/O: 1.550v
ICH Core: 1.100v
DRAM Voltage: 1.500v
DRAM Termination: 0.750v
