Rexse7en44
- Apr 20, 2004
Ok this is getting just a little out of hand. Just when I fix one problem, another comes. Well now what happened is I had just finished installing windows, and I was getting some error message about lsass.exe with error status code 128 and a message that windows 2000 will shut down and restart in a minute, and then my machine does restart after a minute. I saw a page on microsoft.com that says that bug is fixed with service pack 4. But in the process of downloading it everytime I would get the message and my computer would shut down before I could get the update finished. So after about the 4th or 5th time of this happening my computer wouldn't boot up, and just went in circles from the Bios screen to the windows start up screen, then reboot and go around in that loop over and over.... Then I tried to format the drive and it came up with the message : checking existing disk format. Invalid device parameters from device driver. Then goes back to the E:\ promt. I tried using FDISK and deleting the primary partition, and creating it again, and that didn't work. Now I've kind of been sitting here stumpted as to what to do?? Any idea's?
