can't find replacement cable from sound blaster ZxR 3.5mm to RCA cable
Happy Hopping
[H]ardness Supreme
I have the original sound blaster ZxR cable, the 3.5mm to RCA cable is so poorly build that it broke when I push the speaker towards the wall. i.e., the housing of the cable is weak
So I want to buy a cable w/ better housing, but I can only find this :
https://www.monoprice.com/product?p_id=5346
and it looks like it has some stupid rubber that merge the right / left channel together. But the photo is not clear.
where do you have a cable that 1 end is 3.5mm stereo and the other end is RCA but w/o the rubber merging the right / left channel?
Zepher
[H]ipster Replacement
Happy Hopping
[H]ardness Supreme
But look at the 2nd link, there is a piece of rubber that merge the red and the white RCA, so I cannot connect them to the speaker, the speakers are 4 to 6 ft. apart.
Further, I prefer to have these cables braided.
So far, I only find this piece of shit that is NOT braided
https://www.ebay.com/itm/Dual-Shielded-3-5mm-Male-to-2RCA-Male-Stereo-Audio-Adapter-Cable-Cord-1-8m/113299541629
and that's how the last one is broken. I push the speaker towards the wall, the housing broke
why do these people have to have that thing that merge the right/left chnl.? I mean, it's not really 2 cables, it becomes 1 cable
Happy Hopping
[H]ardness Supreme
Happy Hopping
[H]ardness Supreme
I try that, I was doing the 2 x RCA Line out jack 1 and 2 to the 2 x RCA of my speaker, and the sound doesn't come out right, I can't remember the details, so I switch back to the 3.5mm jack
thesmokingman
[H]ardness Supreme
So you need a replacement, higher ql?
https://smile.amazon.com/gp/product/B004YEBK66/r
Happy Hopping
[H]ardness Supreme
you're not reading the original post. It doesn't work for me w/ that piece of rubber, they can't split, as I need to go to 2 speakers, 4 ft. apart
Zepher
just get the RCA to XLR cables, maybe the ones you had were faulty or what, I don't know, but I am using a set on my other PC to my M-Audio BX5's with no issue.
If you must use 3.5mm to XLR cables, these are the ones I have and have been using for the past 5 years,
https://www.amazon.com/gp/product/B000068OEO/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
pendragon1
[H]ardForum Junkie
yeah just get right angle rca extensions. and learn how to problems solve...
Happy Hopping
[H]ardness Supreme
what a coincidence, that's the one I mark as well
Do you find a noticeable difference in sound vs. the RCA jack going to your speaker? I also use M-Audio, M3-8
Happy Hopping
[H]ardness Supreme
that's a great link. That's what I'm looking for, but I agree w/ you, that price is quite high. it's decision time for me
Zepher
but you don't need that style as you have RCA outputs on your soundcard.
You aren't using the powered headphone jack to hook up to the speakers are you, or the surround channels output?
Happy Hopping
[H]ardness Supreme
I know, I have tried to use the RCA output, I can't get it to work. So I go back to the 3.5mm stereo
I can't remember what the problem is
Zepher
Well, go ahead and order the RCA to XLR cables and try it again. Or hook them back up if you still have them.
