I've got a Thomson ST546 DSL modem/router and a Linksys WRT350N running dd-wrt v24rc4. I want to have my Linksys router do all of the routing work, as the current setup is rather shaky with both trying to act as routers (double NAT and all that).
From what I've been able to find in researching this myself, it appears that it should be possible to set the ST546 to run in bridge mode, which will then allow my WRT350N to do all of the work. However, everywhere I've seen that calls this setup the solution doesn't bother to say how it's actually done. Apparently it's assumed that I'll know how to do it, which isn't the case .
Do any of you have experience with this type of setup and have more information as to how to get things properly setup? If you need any clarification of what I said, don't hesitate to ask.
Thanks!
Thanks!
