stop!theradio
- Jul 13, 2007
I'm using Windows 7 Ultimate RTM and I want to shrink ANY of the volumes so I can dual boot with another OS. The problem is, when I go control panel>administrative tools>create and format hard disk partitions, and I select a volume to shrink, I get the "Querying" box for a second and then right after, it says:
"The service cannot be started, either because it is disabled or because it has no enabled devices associated with it."
I know for a fact that virtual disk service is enabled and running. Any idea what it could be? I just need 10-20gb of space for this second partition that I want to create, and I have ample space. Any suggestions?
