bonkrowave
- Oct 12, 2004
Thoose in the know, Please Answer
While we are on the subject ..... I have a question about watercooling !
I am about to make my foray into watercooling and I have an idea that I would like to try. I am worried about one thing tho. Condensation
Since I live in Canada, I thought it would be a good idea to use the Canadian climate to my example. I am looking at the Swiftech H220 kit But I would like to make some alterations to increase cooling. The idea I have is since my computer is so close to a window ... why not stick the radiator in the window to cool down the water. It only seems logical that cooling water further would increase performace, much the same way a cool day gives a noticable increase to my 944.
So since I work at a metal Place I am already in the process of having a shroud for the raditor that will fit in my window (kinda like thoose plates for window air conditoning. Although this one will have a hood to prevent the elements from getting directly on the rad. It will also be foam backed to keep the cold from bringing my apartment to sub-zero temps.
This all seems logical to me .. except with very cool temperatures I am worried of condenation building up around CPU socket. Will this happen and is there a way to get rid of it. Also if I mix antifreeze in the water I would suspect the ice will not block flow through the rad.
Also would it be a good idea to locate the resevoir near the window as well ? to cool holding water ??
Anyway let me know I am just a huge asshat ... or if I really have something here.
Thanks
Thanks
