Can you play DTS CD thru a DAC + 2 channel speaker system (no receiver)
Happy Hopping
In my workout room, my setup is DVD player to DAC, DAC to 2 active speaker
Currently I can't play this DTS CD.
I can play this DTS CD in my other room where I have 5.1 chnl. sys. w/ a receiver. But my speaker in the workout room is much better.
my DAC doesn't input analog audio. Its input is either digital Co Ax, Optical toslink or USB
and I think if a DVD player can't decode a DTS CD to 2 chnl., then I'll just won't buy DTS CD. It's good to know as I only have one so far.
You can setup your dvd player to output PCM vs bitstream, try that before you buy a new DAC. You'll probably have to hook it up to a TV or monitor though to get to the setup menu.
