crazycrave
- Mar 31, 2016
I have been playing with Ryzen Master for awhile now with 3 different cpu 's and it has been my understanding to overclock is to do all cores at that locked speed as why Gen 1 has issues pass 3.9Ghz but working with the Gigabyte 350B board I am at F24 bios. I now find that with my 1400 I can set 1.4v and rise to 3750Mhz with all MT on and set ram to 1.2v at 2400Mhz CL 15 and memory VTT 0.6v and VDDCR 1.1v under a balance power plan in Gigabyte software ,
So now the 1400 has dynamic clocks as to turbo to 3750 all 4 cores with HT enable as needed but drop when not needed as I have watched it go from 1500Mhz to 3750Mhz with the Ryzen tach and the temps scales with the turbo clocks ..as the stock turbo for this cpu was 3.4Ghz baked in and it blows passed that now . So have any of you that have your cpu turbo the overclock please raise your hand as a better way to go turbo ?.
I revised the overclock and made a ReLive video as to see the clocks scale the load
I turned the memory on the 290x to 8000Mhz http://www.3dmark.com/fs/17964596 Hello RX 580
