^eMpTy^ said:Some have claimed in the past that they can, but most don't even try. So if you overclock with the stock heatsink/fan on the card, you're probably ok. However, if you destroy the card, you HAVE voided your warranty.
Overclocking, in most cases, doesn't yield a significant benefit, so unless you're prepared to destroy your card, don't bother with it...and if you do destroy your card, take it like a man, don't try to RMA it.
It generally does offer a significant increase. I've never destroyed a card through overclocking, but I don't do volt mods (I did try the 1.5v BIOS on the 7800GT, but it offered very little extra so I flashed back. Same with a 6800GTO I had).^eMpTy^ said:Overclocking, in most cases, doesn't yield a significant benefit,
I'd say it's more like a 15-20% improvement on average for an overclocked 450/1320 7900GT. That is unless someone does a volt mod.MelchiorZ said:Well... that depends. Hows about 28% improvement sound from overclocking most 7900GTs
pxc said:It generally does offer a significant increase. I've never destroyed a card through overclocking, but I don't do volt mods (I did try the 1.5v BIOS on the 7800GT, but it offered very little extra so I flashed back. Same with a 6800GTO I had).
I did happen to test a 7800GT @ stock vs BFG 7800GT OC vs overclocked to 465/1180 and a 7900GT @ stock vs XFX 7900GT Extreme 520/1500 vs overclocked to 545/1750 in several games (the thread is in the nvidia forum).
Overall, the stock overclock on the BFG 7800GT OC gave a 5.65% improvement over 400/1000. Further overclocking it to 465/1180 gave another 8.45% improvement over 425/1050.
For the 7900GT, the stock 520/1500 overclock averaged 9.40% over reference 7900GT 450/1320 speeds. Further overclocking it to 545/1750 gave another 6.19% improvement over 520/1500.
Since even stock 450/1320 7900GT cards are capable of hitting at least 520-530 on the core and 1600 on the memory, a 10-12% improvement is nothing to ignore. There's less headroom for factory overclocked cards, but the improvements can still be significant.
I paid $300 shipped for a pre-overclocked XFX 7900GT Extreme. Now stores are just gouging.^eMpTy^ said:Right, so pay an extra 30 bucks and get a pre-overclocked card...that's all I'm saying
M'ichal said:Thanks for your insight guys.
The thing with my card is really weird, because it it was working fine for pretty much a year at 570/1150 (vs 500/1000 stock). And a week ago I was playing NFS:Most Wanted at
530/1050 and bam! The screen froze, I restart, go back to the game and there are artifacts. And same in any other 3D game.
The heatsink was pretty dusty though, so I suspect that might be a reason why it screwed up. I pulled chunks of dust from it. You think that might've contributed to a high temp and a burn?
Michal
