Can two USB keyboards be connected at once?
undertheradar
Can you buy two USB style keyboards and use them both at the same time on the same computer? Has anyone tried this/know what will happen?
My goal is to use one keyboard for each hand. There are split/tented/vertical keyboards out there, but they dont seem to have a key design that I really like, so I would like to use two keyboards that I do like (provided they are USB), one for each hand mounted vertical, and then I can simply ignore the upper half on each board that the other hand uses (or, if I need to type one-handed for some reason, I can still do that).
Will this create some internal conflict or reduce the total number of keys or split the total number of keys that I can press in some way? Are there some safeguards built into a computer to prevent this (so I couldn't say, press the left and right arrow keys at once and cause my computer to catch fire).
Falkentyne
Should be no problem ata ll. I've had a ps/2 and usb keyboard attached at the same time without issues, and USB is newer tech; no reason why it wouldn't work. The only problem, if any, would be if there was a limit on simultaneous keypresses or something...But yeah, even some custom game controllers use a usb keyboard encoder (e.g. for programming keystrokes into buttons or direction switches)
Oldie
Mean Old Administrator
Staff member
Why would you ever need to type one.....oh.....nevermind. :p
Yeah, it works just fine. I just plugged in an extra for kicks, and it didn't see any issues.
Haste266
shouldnt be a problem. i have a wired and a wireless set of input devices attached to my machine via usb without issue.
RadioDude
I can guarantee you that it'll work, I have a g15 and a saitek eclipse 2 plugged in once to test it out. Not only that it also works when i have my saitek plugged into the g15 which was already connected to the pc
zoobaby
Yes it is fine. It wont break any thing.
In fact I currently have 3 USB keyboards attached to my laptop. The keyboard of the laptop is one, an external usb keyboard is the second, and the third is a usb device that I have programmed to enumerate and behave like a keyboard.
undertheradar
Cool, thanks guys. Now I can make a tie-fighter board with a couple cheapo USB boards rather than pay $100-200. My main concern was that one might boot and the other might not.
