Can the P180's PSU chamber fan be mounted in the front?
meatfestival
Had a good search but I don't think anyone has answered this.
I'm thinking of moving the bottom fan to the front (in the main chamber, not the bottom), has anyone done this? Preferably with the hard disk cage in, and without cutting or drilling. I'd have a look inside the case, but I've just got everything back in there and don't want to start pulling stuff out again until I know for sure.
Eagle156
I think I saw this done before, but I don't remember where. I'm pretty sure you won't be able to use the hd cage after that.
AeriaGloris
I've mounted a 120mm fan at the front in the lower chamber, but that was with drilling and you can't use the lower hard drive cage then.
Eagle156
oh nvm, I just reread his post again. You can do that without any modification, I believe there's a clip at the front that allows you to put your fan in there.
slickmitch
On mine the bottom (psu) tricool is a 38mm fan. If I put this fan in the main front I would not be able to use the hdd cage on top. It will fit with no hdd cage.
