Can ping web sites but now browse.....
Discussion in 'Networking & Security' started by Dave851, Nov 3, 2010.
  1. Dave851
    Dave851 n00b
    6
    Oct 24, 2010
    Ok well I am havin werid issuses, internet explore can not browse the internet.
    Things i have tryed
    1. Reset modem, nothing
    2. Reset IE, nothing
    3. Tryed Firefox, nothing
    4. Pinged google by name and ip in CMD, both pings worked
    5.Flushed DNS cache, nothing
    6.Flushed TCP, nothing
    7.Reset Winsock, nothing
    I'm running out of ideas here anyone else think of something i missed?
  2. Bone_Enterprise
    Bone_Enterprise Enter in the Rear
    4,443
    Apr 21, 2006
    Check your hosts file and make sure everything there is set as default and does not have rogue addresses in it?
  3. Dave851
    Dave851 n00b
    6
    Oct 24, 2010
    Ok I'm new to networking, i'm reading and learning as i go. I been on google for 3 hours and have run out of options. Please explain how to check that and what relation it would have to my problem, i like to learn by doing so i'm going to ask about lots of things please be patiant with me thank you
  4. Shamb1es
    Shamb1es [H]Lite
    93
    Oct 7, 2009
    Go into your browser settings and check if it is trying to go through a proxy. The womans machine was recently affected and both the virus set both FF and IE to run a proxy through your own computer through port 53000 or close to that. After the virus was removed the proxy stopped working and the browsers stopped working, just had to turn off the proxy again.
  5. Dave851
    Dave851 n00b
    6
    Oct 24, 2010
    This network does not use a proxy. Also, I just connected to the computer from my house useing teamveiwer, so the internet is conected, its browseing problem.
  6. Lateralus
    Lateralus More [H]uman than Human
    13,748
    Aug 7, 2004
    What Bone_Enterprise meant:
    Go to the C:\Windows\System32\Drivers\Etc folder. Double click on the "hosts" file and open it with Notepad.
    It should look something like this:
    Code:
    # Copyright (c) 1993-2009 Microsoft Corp.
    # This is a sample HOSTS file used by Microsoft TCP/IP for Windows.
    # This file contains the mappings of IP addresses to host names. Each
    # entry should be kept on an individual line. The IP address should
    # be placed in the first column followed by the corresponding host name.
    # The IP address and the host name should be separated by at least one
    # space.
    # Additionally, comments (such as these) may be inserted on individual
    # lines or following the machine name denoted by a '#' symbol.
    # For example:
    #      102.54.94.97     rhino.acme.com          # source server
    #       38.25.63.10     x.acme.com              # x client host
    # localhost name resolution is handled within DNS itself.
    #	127.0.0.1       localhost
    If there is anything else in there, that could be indicative of a problem.
    Have you tried running a scan with Malwarebytes or Spybot to search for malware? Tried another browser to make sure it isn't just IE that's not working?
  7. Dave851
    Dave851 n00b
    6
    Oct 24, 2010
    yup 3rd thing i did. And scaned with anti-virus norton, malwarebytes the norm. no viruses. I just googled and read up on the host files, the one in the pc is identival to the one you posted..
  8. Nocturnal
    Nocturnal Gawd
    790
    Jul 20, 2006
    Was Norton ever installed?
  9. Vito_Corleone
    Vito_Corleone [H]ard|Gawd
    1,730
    Dec 17, 2006
    Sounds like goofy proxy settings...
  10. munkle
    munkle [H]ardForum Junkie
    11,186
    Jan 16, 2005
    I had this problem once, make sure your dns settings are correct. If they are set to automatic, enter something in save it and then set it back to auto and save it. For some reason that will fix it sometimes.
  11. Dytralis
    Dytralis Limp Gawd
    358
    Feb 6, 2003
    google "winsockxpfix"
    try that and see if it clears your issue
  12. gimp
    gimp [H]ardForum Junkie
    9,825
    Jul 25, 2008
    what anti-virus solution are you using?
  13. exchange keys
    exchange keys Limp Gawd
    339
    Feb 18, 2009
    Is this happening on Windows XP, Vista, 7?
    I see Dytralis stated "winsockxpfix", but I don't see the OP actually mentioning what flavor of Windows he has.
    Whenever I get something like this, I also check for what Windows updates have been installed. For my brother's laptop, he had a similar problem. He has Windows Vista Home Premium 32-bit, and after I uninstalled some KBs, his web browsing started working again.
    So, check that out. Any recent KBs that were installed when this started happening?
  14. Mister Natural
    Mister Natural 2[H]4U
    3,448
    Oct 10, 2002
    Yep seeing this more often lately. A pc gets infected, cleaned and the proxy setting is still enabled. Go to internet options, connections, lan settings, remove check mark on proxy server setting.
  15. Dave851
    Dave851 n00b
    6
    Oct 24, 2010
    Ok well its running Windows 7 home 64 bit.
    Norton is installed on the pc. I checked firewall setting and they are fine.
    Vito: There are no proxyes being used.
    Keys: I do not use this pc and i can't get a clear date when this started.
    Mister: There is no check in the poxy box
    I did reset TCP/IP and winsock with the netsh command utility in cmd
  16. Nocturnal
    Nocturnal Gawd
    790
    Jul 20, 2006
    Remove Norton using the Norton Removal Tool (Symnrt.exe) and try again. Regardless of if the firewall was disabled or enabled sometimes it gets screwy. Try it, let me know if it helps.
  17. gimp
    9,825
    Jul 25, 2008
    definitely try this.
    I have seen Norton and McAfee screw up browsing, even after stopping the services.
  18. slayer9019
    slayer9019 [H]ard|Gawd
    1,598
    Apr 2, 2010
    live boot into linux or tinyxp...if it works. check further
  19. edicwhun
    edicwhun [H]Lite
    93
    Mar 30, 2006
    Make sure port 53 isn't being blocked on your firewall for some reason (this is commonly the port for DNS). And what are your DNS settings? Are you getting them from your ISP or do you have your own server set up?
  20. doctah
    doctah Limp Gawd
    392
    Feb 8, 2008
    Can you get to your routers config page (assuming it has one)?
    Since you can ping google - can you access it via IP?
    Can you try it in safe mode w/ networking?
    I'm thinking spyware/virus. If it were some crazy DNS setting, host file, etc, you shouldn't be able to ping google by dns.
  21. edicwhun
    edicwhun [H]Lite
    93
    Mar 30, 2006
    Shoot, over looked the part where OP was able to ping Google by IP AND name!
