Hi, I have a Corsair HX850 850 watt PSU that I'm sending back for RMA, but the only PSU I have to use until I get a replacement is an even older Corsair HX620, 620 watt PSU. You can see in my specs I have a 2080. So, the 620, only has an 8-pin PCI-E cable. My question is, can I plug in a PCI-E cable from the 850 and plug it into the 620 because the 2080 requires a 6+8-pin connector?
Thanks in advance!
Thanks in advance!
