Can I use my wireless router as a bridge?
Discussion in 'Networking & Security' started by Morrie20, Aug 19, 2004.
  1. Morrie20
    Morrie20 Limp Gawd
    233
    Oct 24, 2000
    I just moved and my roommate has a wireless network. He has a wireless G router that his computers have no problem with. My poopy usb compaq 80211.b adapter, however, disconnects every 2 minutes. I'm sitting a floor above the router, so there shouldn't be any problems.
    I just wanted to know if there was any way to salvage my linksys BEFW11S4 and make it a bridge before I go drilling a hole for cat5. I have XP and I tried the whole services.msc/wireless zero config utility to try to fix it but it didn't work.
    Plz help and thx
    Mo
  2. acascianelli
    acascianelli [H]ardness Supreme
    6,838
    Feb 25, 2004
    use netstumbler to see how much signal strength you have, maybe see if your room mate wants to get a signal amplifier so you can get better signal strength. also, ask him if he has his wireless power turned down on his AP. i know on my router i can set the wireless power settings from 100% to 75%, 50%, 25%, 12.5%.
  3. Morrie20
    Morrie20 Limp Gawd
    233
    Oct 24, 2000
    i didnt think it was signal, but i tried stumbler anyways.
    So can I do this with my router?
  4. Clutchcargo
    Clutchcargo n00b
    7
    Aug 17, 2004
    Bump,
    I'm also interested in this. I have the same Linksys router that I want to use as a wireless printserver. I didn't see an option for wireless bridge anywhere in the firmwares option menu.
    The pieces I have are:
    Belkin Wireless G Router,
    Linksys Wireless B router,
    Hawking Wired PS.
    Thanks for any ideas.
    Cjh
  5. Morrie20
    Morrie20 Limp Gawd
    233
    Oct 24, 2000
  6. Falls Included
    Falls Included I'm happy & gay too
    3,703
    May 30, 2003
    give it a try. cant hurt.. just turn off nat, and firewall
  7. K1llaB
    K1llaB Limp Gawd
    356
    Oct 13, 2001
    I am not sure the W11s4 can act in that mode. I had a spare one laying around i wanted to "convert" to just an AP. I had the latest firmware but it never wanted to get out of router mode. I tried the same thing w/ a DLink & it worked fine. Not sure if i was missing something in the Linky GUI, but i couldnt get it to work.
