My GTX 970 has always locked up when gaming if temps go above around 50-50C, if I put the fans on manually to 80% and keep the temps below 50C, it never locks up.
I recently removed the heat sink and damaged the sticker over the screw, but replacing the thermal paste didn't correct the problem.
Do you think I can still send this back to ASUS, or will they definitely deny warranty?
Card basically works as normal, just that it locks up randomly if I don't set fans at 80%+.
Thanks.
Thanks.
