Can I really whinge about H/Z270 ITX options and dual monitors?
Discussion in 'Motherboards' started by AbRASiON, Jan 4, 2017.
  1. AbRASiON
    AbRASiON Limp Gawd
    345
    Jul 28, 2004
    Why on EARTH are these idiot manufacturers putting only 2 video outs on the motherboards, or they are putting 2xHDMI on them? HDMI? WTF?
    I have 2xDell 30" monitors 1xDell 24" monitors.
    Yeah I'm an "ITX guy" and honestly, I thought it was getting more popular?
    My Asus H97i can totally drive 2 high end displays.
    Asus H170i same thing.
    I can't believe this omission. If I want the latest motherboard in ITX form factor, I'm forced to buy a video card? I know I'm in the minority on that one for enthusiasts but I don't game anymore, but I do want a beefy-ish, cute little machine.
    Man am I annoyed.
    Was really hoping to try Asrock for a change for the $$ savings, found the problem, then checked the others, pretty much every single company has screwed this up.
    WHY 2 HDMI I'm still shocked, wtf?........
  2. Bandalo
    Bandalo [H]ardness Supreme
    4,752
    Dec 15, 2010
    I don't understand your complaint. The Asus Z270 has an HDMI and a DP...I don't think I've seen any ITX boards with 3 digital video outs in a long time. Most full size boards don't have that feature either.
    You should be able to chain 2 DP monitors if you have to, depending on which model Dell 30" you have.
  3. AbRASiON
    AbRASiON Limp Gawd
    345
    Jul 28, 2004
    1x HDMI and 1xDP allows me to run 1 monitor at 4k and 1 monitor at 1080p.
    H170 boards from only 12 months ago support what I need 2 "high end" outputs (dual link DVI + DP or dual DP, or heck even 2x Dual link)
    this is a step back.
    I have a Dell U3011
  4. Quartz-1
    Quartz-1 [H]ardness Supreme
    4,331
    May 20, 2011
    If you look at NUC boards you typically get a HDMI port and a Displayport port. Support for only two monitors seems to be the standard now.
  5. AbRASiON
    AbRASiON Limp Gawd
    345
    Jul 28, 2004
    That is a NUC though. I mean my 18 month old H97I from Asus does what I need. I believe the H170I from Asus does too.
    Sadly it looks like ANY overclocking on the H series is a goner now,.... so I need a Z series but ALL the damn Z's are "gamer elite" crap with fantastic soundcard "killer nics" and 1 or 2 video out.
    Also I didn't find a H270 even if I didn't overclock to suit my needs.
    Shocking about the dual HDMI though, what possible purpose could people have for it? It's utter madness.
