When I'm on the 2nd story of my house with my laptop apparently we get some signal from a neighbors linksys router.. and my connection will drop.
I used to have this happen and the wireless icon would show itself not connected (with an x) and then trying to aquire network address to the other network.
It doesn't do this anymore, but when I check the wireless networks in range when I have this problem, the linksys always shows up with one bar. If I disconnect from my link and reconnect (Dlink) everything works fine.
I don't have the linksys in my preferred networks, and I even added it at one point to uncheck the 'connect when this network is within range' box. Is there anyway to control my wireless card so that it only attempts to connect to my d-link or nothing? Kinda like Bluetooth can see all other wireless networks but you tell it which to link to and that's that.
I appreciate any help
