The Phantek fans I bought for my new build came with really long rubber anti-vibration pegs to use instead of screws for mounting. The fan mounts in my case attach the fans from the side of the fan on inside of the case not the one facing the outside. As a result te pegs extend well past where the front of the case would go (visible via the drive bay cover above the fan. To put the external grill in front of the fans and close the case up, I'd need to cut the pegs at either the red or (maybe) the orange line to make them stop from going far enough forward to be a problem. Can I do that and still have enough of the peg to hold the fans well?
