Hi all. Gave up after a few pages of search listings with no luck.
As title says, can I get 4k on a 4k tv using a DVI-D to hdmi cable? I know DVI-D can support the resolution, but what I havent seen is if a tv will barf at me and not accept the signal since its a dvi cable on the other end. I know this setup works fine with 1080, but I dont know if 4k is wonky enough for it not to work.
The tv will be used only for office and coding stuff, so getting a tv that only supports 30hz is no biggie.
