Can Asus 3080 TUF fit on Asus TUF x570 mobo? chipset heatsink concerns.
amd7674
The x570 HS fan on Asus mobos looks it might be in the way. For that reason I'm leaning toward buying MSI offering i.e. Tomahawk x570.
Please advise.
MavericK
Zero Cool
I don't think the cards stick up above the PCI-E slot too much, seems like it should be fine.
amd7674
I'm using the same motherboard and video card you listed right now and there's no issues.
Thank you for your feedback. I went with Tomahawk, due to better VRMs and temps. Zen3 CPUs seem to be very temp/power sensitive (based on user's feedback) and figured every bit helps. TUF was my second choice and it would work better with iCUE ecosystem.
