I have a motherboard where the socket placement was simply not that smart from the manufacturer(MSI Z87M Gaming)and as such it makes dealing with video cards incredibly frustrating with monster CPU air coolers. If at all possible I'd like to see if there is anything comparable in performance to the NH-D14, while being SMALLER than 140mm "wide"(this is the measurement from top to bottom when the motherboard is mounted vertically in a case, or from left to right if mounted horizontally. The fans on the NH-D14 do not make it any wider so that's not he issue, it's the block itself.
Please advise.
Please advise.
