Can anyone recommend me a wifi router/LAN splitter, with LAN ports that can hit 1.5Gbps?
Discussion in 'Networking & Security' started by Gatecrasher3000, Nov 19, 2019.
  1. Gatecrasher3000
    Gatecrasher3000 Limp Gawd
    310
    Mar 18, 2013
    So, I just got a new apartment, and I was able to get a new ISP that offered 1.5Gbps, so I upgraded my package to 1.5Gbps. However, for some dumb reason my Asus RT-N66U routers can only hit 800mbps over LAN (I have read it's a problem with them), so I'm looking to upgrade. What is the new hot wifi router/LAN splitter that can hit 1.5Gbps over LAN? What are you guys using?
    I have already upgraded my NICs and ran Cat6, the new router is the last step in my new network.
  2. IdiotInCharge
    IdiotInCharge [H]ardForum Junkie
    12,486
    Jun 13, 2003
    You want a >1Gbps router?
    How is the connection from the ISP provided?
  3. rhansen5_99
    rhansen5_99 [H]ard|Gawd
    2,034
    Nov 12, 2001
    Check out the ubiquity edgemax devices
  4. Valnar
    Valnar 2[H]4U
    3,077
    Apr 3, 2001
    Well any consumer firewall these days might get you 1Gb, but not higher. You'd need a 10Gb or Multi-Gig interface to go above that. I've never seen an ISP offer that before.
  5. Machupo
    Machupo Gravity Tester
    4,955
    Nov 14, 2004
    Sounds like a perfect time to build your own pfsense box with dual 10gbe ports (supermicro makes some good boards in mitx format / 1u rack size).
