dbwillis
- Jul 9, 2002
I updated a pool of machines, brand new ones, out of the box, (HP Z240) from 2x 256gb SSD to 1x 256 and 1x 1TB SSD
Simple swap of the 2nd drive (its in AHCI mode) to a larger one.
I thought I had a bad drive, but all 3 do the same thing...
When I take the removed/new drive and place it into another PC, the BIOS sees the drive and correct info, but upon bootup I get a message about drive 1 failure (when its the 2nd drive in another PC)
- tried to pop it into a USB enclosure and format it, AOk, still cant install to it and get the device error
- tried to pop it into another PC as a single drive and install Win7 to it, it sees the drive, can partition but not format, says it cant install to it, mentions "your PC cant boot to this device, make sure its enabled" (not the exact words)
Its the same model drive thats still in the Z240 and installs fine (swapped the drives and have the same problem)
Found a firmware tool on Hynix site, but its older than on the drive
Anyone have any ideas?
Drive info :>
SKHynix SC300 256gb
PN - HFS256G32MND-3210A
Firmware - 20131P00
Drive info :>
SKHynix SC300 256gb
Firmware - 20131P00
