My current system is one year old. Up until the last week it was powered by CoolerMaster B700. It was a 5-year old PSU I bought back in the day when my previous PSU died and I was in a hurry.
For the one year life of my system I had two freezes, one in BIOS/UEFI when I was fiddling with fans settings (few months ago) and 10 days ago when I was just writing something in Firefox (computer was idle). Total freeze, image frozen, nothing reacts.
Is it possible that the Cooler Master PSU caused these?
Some thoughts that might be helpful. I had my doubts about this B700 from day one (that's why I finally replaced it with new one). Now when I researched more, it turns out this PSU was total crap. In my old system (AM2) voltages were 12.6 and 5.26V. On the edge or beyond the specs but it worked Ok.
On my current system voltages are 5.3V and 12.5V (idle), I guess the older system used more of 5V.
After testing the CM PSU standalone outside (with a wire between green and black) with 35W lamp, strange things happened (compared to another one spare I had, FSP). After I load the 12V line with the lamp, it shows 12.4V and 5.3V. When I disconnect the lamp (but a test fan stays connected) the 12V line becomes 13.4V for 1 to 4 seconds and then drops to 12.3.
This (these) isn't observed with the other PSU I tested.
Plus the fact this PSU is crap, I want to avoid the dangerous BIOS update if I can, because the PC works fine otherwise. My BIOS is from October 2017.
So, is it possible this PSU caused those freezes, for example a temporary higher voltage could have caused some component to cause the freeze.....?
Thanks.
Thanks.
