RegisteredToPost
- Sep 21, 2004
http://www.hardforum.com/showthread.php?p=1028649231#post1028649231
http://www.hardforum.com/showthread.php?p=1028647921#post1028647921
Basically, i bought system upgrades at tigerdirect.com. asus a8nprem, evga 7800gt, silverstone 680wpsu, 1gb crucial ballistix.
The short version: I had to install fresh xp install. Booted a few times, terrible stability. one final crash after windows update, system will not post. All temperatures are fine. The scythe ninja keeps idle temps below 30c with as5.
The psu makes the lights dim a bit, and makes a tick when you switch it on, from off...i'm wondering if the psu is bad, or is that normal for high power supplies? I would really like to know if RA just the motherboard would be advisable here? The sli light is always off on the mainboard-not sure if that's standard procedure either.
