Sup [H].
I have kind of weird question. Today at work a customer gave me an Antec Smart Power 450W Power Supply saying that it was dead. Thinking this was kind of strange as there seemed to be no fault, or smell, I asked if I could have it and he said no problem.
I took it home and suprise, suprise it seems to work no problem in an old system of mine. Is it possible that it hiccuped or more likely that it failed or 'died' under the load he was using it under, but has no problem's running a lighter system?
After googling "test dead power supply" all the results I found seemed to say that the surefire way to test a PSU was by plugging it into an old computer with a functioning mainboard.
Also, I'm trying to upgrade my current setup but am on a tight budget, and would like to use my existing Antec TruePower 550W on a Quad Core based system running an 8800GT and probably 2-3 HD's. Anyone see a problem running my current rig [see sig] with this 'refurb' Antec 450W assuming it doesn't blow up in the next few days.
EDIT: Is there a diagnostic tool or program like Prime that can be used to test/load a PSU
Thanks
Thanks
