I'd venture it can drive the displays, but probably won't be able to run games maxed out at that resolution. That's a lot of pixels. Curious for a more well informed answer.
you looking to use both monitors at the same time to game? If so, you will not be running anything on ultra, high, or probably even medium at those resolutions on a 590.
you are nearly doubling the pixels going from a 1080p monitor to a 1440p one. It will take some power to run 2 of them at a decent framerate.
Nice. Thanks for the pro tip. If I do upgrade what should I upgrade to? GTX680/690?
but for your needs... you could get away with a $100 card with two outputs. am I missing something?
I went from a 1.5GB 580 to a 590, each at launch. The 590 was effectively 570SLI. This was for a 5760x1080 3D setup. The 590 was not enough. My only options were to go 590 x2 or go tri-sli 580 3GB. I chose the latter.
that makes more sense. you're going to run into non-GPU related issues doing this, however. you'll either have to run the game in windowed mode and force yourself to keep the cursor in the game window, or run the game fullscreen and have the cursor locked to the game (making the second screens content inaccessible unless you ALT+TAB out).
if you're okay with those options then you should be okay to proceed. I would personally find either of those scenarios annoying and unusable, but to each his own. you should be (technology capability-wise) able to do this. whether you'll find it actually a usable solution is another matter entirely.
