Campaign to get newegg to stock the 6150K8MD
Soymilk
take a look at this thread here: http://hardforum.com/showthread.php?p=1029740035#post1029740035
the foxconn 6150k8md-8ekrsh is a socket 939 matx motherboard with some improvements over the 6150k8ma, namely integrated dvi. i've contacted foxconn, they said they have it in stock and it's up to the vendors to place an order. my plan is to bombard newegg with so many product suggestions for this motherboard that they'll go "holy crap!" and place an order :)
please help even if you don't want this particular mobo, it takes less than a minute. thanks!
Soymilk
so... this has to do with amd motherboards and sff at the same time. i have to choose only one place to put it? or would it have made you happier if i just copy pasted the body of the other thread here instead?
