Camera Path in 3d studio max
Grazehell
ok guys I need to know if I can( I suppose I can) have a path made for a camera to follow.
I want to do a scene where the camera moves about on various axes.
I want to know how to make a path for that camera to follow.
Hope some can help.
badjoke
yes you can
you make a line, make it not renderable and attach the camera to line via motion spline and set the distance it moves per frame then render;)
c/o optional
Demonfyre
yeah you can create a spline as your path as was said above...you can then use the track view/graph view to change the speed at which the camera moves or rolls or wahtever along the length of the line...
Grazehell
cool thanks guys...I knew you could use the spline for animating object but for some weird reason this idea for a camera totally did not come to mind...guess I am more of a newbie with max than I thought.
Thanks again.
