calling any Visual basic guru's
Status
Not open for further replies.
Shadowspawn
I am working on a network diagram with Visio 2013 and need a way to toggle some connectors off and on. The trick is that when one layer is turned off I want the other layer to turn on. Here is what I have at the moment:
Code:
Private Sub CommandButton1_Click()
Dim LayersObj As Visio.Layers
Dim LayerObj As Visio.Layer
Dim LayerName As String
Dim LayerCellObj As Visio.Cell
Set LayersObj = ActivePage.Layers
For Each LayerObj In LayersObj
LayerName = LayerObj.Name
' Debug.Print LayerName
  If LayerName = "Core 1 connections" Then
    Set LayerCellObj = LayerObj.CellsC(visLayerVisible)
 LayerCellObj.Formula = False Or 0
  End If
Next
End Sub
Private Sub CommandButton2_Click()
 LayerCellObj.Formula = True Or 1
  End If
Next
End Sub
Private Sub CommandButton3_Click()
  If LayerName = "Core 2 connections" Then
  End If
Next
End Sub
Private Sub CommandButton4_Click()
  End If
Next
End Sub
These are four buttons. The first two turn layer 1 (Core 1 connections) off or on. The second two do the same for layer 2 (Core 2 connections). I know I can do this in one button but my programming skills are nonexistent. I can figure it out over the course of a couple of days but I was hoping someone here could look and knock it out in five minutes.
socK
if you're just looking to toggle / flip a boolean, you can logically negate it.
Shadowspawn
Okay, sounds good, but how do I do that? I can grasp the theories easily enough, but I don't know the command language.
Can I reference the layer name directly? The current script that I am using looks like it searches through the layers until a matching name is found.
Shadowspawn
I figured it out. I merged two of the buttons scripts so that one layer is disabled when the other is enabled. This gives me one button per layer which will work just fine.
Status
