Calling All Optiquest Q241WB Owners
Morpheus256
I recently bought a Q241WB, unfortunately it suffers from the Viewsonic EDID plague and the info in mine is corrupt.
I'm hoping someone might be able to run MonInfo http://www.entechtaiwan.com/util/moninfo.shtm on their computer, to give me the information to reprogram the edid, as well as create the INF to test it for the time being.
Currently the monitor is detected as a Non-pnp monitor, which limits it to 640x480. I've used the info from my U2408 Dell and it sorta works, but not perfectly, so I know this is the problem.
All I would need from you, is to run the program, and select the "realtime" monitor and File, Create INF.
Thanks!
capNsgt
; INF file generated by Monitor Asset Manager (2.60.0.972), 4/19/2013
; Copyright (c) EnTech Taiwan, 1995-2011.
; Internet: http://www.entechtaiwan.com
[Version]
Signature="$WINDOWS NT$"
Class=Monitor
ClassGUID={4d36e96e-e325-11ce-bfc1-08002be10318}
Provider=%MFG%
DriverVer=4/19/2013, 1.0.0.0
;CatalogFile=YourSignedCatalogFile.cat
[DestinationDirs]
DefaultDestDir=23
[SourceDisksNames]
1=%DISC%
[SourceDisksFiles]
;YourColorProfileFile.icm
[Manufacturer]
%VENDOR%=EDID_OVERRIDE,NTx86,NTamd64
[EDID_OVERRIDE.NTx86]
%PRODUCTID%=OVERRIDDEN-EDID.Install, MONITOR\VSC6021
[EDID_OVERRIDE.NTamd64]
%PRODUCTID%=OVERRIDDEN-EDID.Install.NTamd64, MONITOR\VSC6021
[OVERRIDDEN-EDID.Install.NTx86]
DelReg=DEL_CURRENT_REG
AddReg=OVERRIDDEN-EDID.AddReg, MODE1, DPMS
CopyFiles=OVERRIDDEN-EDID.CopyFiles
[OVERRIDDEN-EDID.Install.NTamd64]
[OVERRIDDEN-EDID.Install.NTx86.HW]
AddReg=OVERRIDDEN-EDID_AddReg
[OVERRIDDEN-EDID.Install.NTamd64.HW]
[OVERRIDDEN-EDID_AddReg]
;Base EDID
HKR,EDID_OVERRIDE,"0",0x01,0x00,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0x00,0x5A,0x63,0x21,0x60,0x3F,0x04,0x00,0x00,0x2D,0x11,0x01,0x03,0x80,0x34,0x20,0x78,0x2A,0x5A,0xD5,0xA7,0x56,0x4B,0x9B,0x24,0x13,0x50,0x54,0x23,0x08,0x00,0xD1,0x00,0xB3,0x00,0xA9,0x40,0x95,0x00,0x81,0x80,0x81,0x00,0x01,0x01,0x01,0x01,0x28,0x3C,0x80,0xA0,0x70,0xB0,0x23,0x40,0x30,0x20,0x36,0x00,0x06,0x44,0x21,0x00,0x00,0x1A,0x00,0x00,0x00,0xFF,0x00,0x51,0x59,0x38,0x30,0x37,0x34,0x35,0x30,0x31,0x30,0x38,0x37,0x0A,0x00,0x00,0x00,0xFD,0x00,0x32,0x3D,0x1E,0x50,0x10,0x00,0x0A,0x20,0x20,0x20,0x20,0x20,0x20,0x00,0x00,0x00,0xFC,0x00,0x51,0x32,0x34,0x31,0x57,0x42,0x0A,0x20,0x20,0x20,0x20,0x20,0x20,0x01,0x64
[DEL_CURRENT_REG]
HKR,MODES
HKR,EDID_OVERRIDE
HKR,,MaxResolution
HKR,,PreferredMode
HKR,,DPMS
HKR,,ICMProfile
[DPMS]
HKR,,DPMS,,1
HKR,,PreferredMode,,"1920,1200,60"
[MODE1]
HKR,,MaxResolution,,"1920,1200,60"
[OVERRIDDEN-EDID.AddReg]
HKR,"MODES\1920,1200,60",Mode1,,"30.0-80.0,50.0-61.0,+,+"
[OVERRIDDEN-EDID.CopyFiles]
;YourColorProfileFile.icm for non-sRGB displays
[Strings]
MFG="EnTech Taiwan"
DISC="Monitor EDID Override Installation Disk"
PRODUCTID="ViewSonic Q241WB (VSC6021 EDID Override)"
VENDOR="ViewSonic"
