Calculators VS Kill-A-Watt --REAL Power Consumption
Discussion in 'Power Supplies' started by sir_rob, Nov 17, 2008.
  1. sir_rob
    sir_rob Limp Gawd
    135
    Jan 27, 2003
    Question: When I upgrade, do I really need to get another 650+ watt PSU to compensate for inaccurate manufacturing specifications?
    I have used many calculators to give me an idea of how much power my computer is using. They all state that my system uses 500 to 650 watts (or they recommend PSU's that will supply that much power).
    When I plugged my computer into my Kill-A-Watt to see how much the PSU was drawing from the outlet, it NEVER exceeded 200 watts under load from before it posted through some stress testing! I ran Prime95 on each core and transferred data from a DVD-RW to a HD at the same time. I assume that if I were ripping from all three DVD-RW drives, running prime 95 on each CPU core, and transferring files between all 5 hard drives...etc, I could get it over 200 watts, but probably not by too much.
    Knowing that the PSU is not 100% efficient, that tells me that even with a large number of components (but low end video card), my system is pulling well under 200 watts from the PSU. Am I missing something here? I have gone through two 550+ watt PSU's on various builds of this computer over the past 5 years. I use a UPS that does not condition the line. I understand that PSU manufacturers are notorious for overstating power ratings. One of the PSU's that failed was cheap, and the other one was a decent Fortron.
    My current system is an Athlon 3800 X2 that has been overclocked at times, but is not currently. I will probably be upgrading to a decent Intel quad core soon. Except for the motherboard and RAM, everything else will stay the same.
    Again: Do I really need to get another 650+ watt PSU? Am I missing something here?
    Specs:
    Athlon 3800 X2
    MSI K8N Neo4
    2 Gb RAM
    Radeon 1300 Pro
    (5) 7200rpm hard drives
    8 USB devices
    (3) DVD+/-RW drives
    (1) 120mm fan
    (3) 92mm fans
    (2) PCI cards
  2. soulesschild
    soulesschild [H]ardness Supreme
    6,049
    Feb 18, 2007
    Posting system specs would help?
    Also, the calculators over estimate
  3. kirbyrj
    kirbyrj [H]ard as it Gets
    24,474
    Feb 1, 2005
    I'm not going to comment definitively, but I was running a OC'd E6600 with dual X1950's in Crossfire, 3 HDD's, DVD drive, 5 fans, X-Fi with front panel, VFD display all on a OCZ Powerstream 510W PSU. In fact, that same system is still running today without the crossfire setup and has had zero issues. I used that PSU for 4 years in many different builds and never had any problems at all.
    Like I said...more of a FWIW.
  4. sir_rob
    sir_rob Limp Gawd
    135
    Jan 27, 2003
    Specs added. Thanks for the replies!
  5. Paul_Johnson
    Paul_Johnson [H] Admin Staff Member
    15,993
    Aug 29, 2004
    Yes and a quick search would turn up this topic a million times over. Here is the recap:
    1) APFC can fool Kill-A-Watts into giving you abnormally low readings (some times giving better than 100% efficiency)
    2) Power supplies derate with temperature anywhere from 2w/c above a nominal rated at value to 10w/c.
    3) Kill-A-Watt's and most power meters sample to slowly to catch transient loads (the Transient load from our tests is 117w and is COMPLETELY missed by Kill-A-Watts).
    4) Power supplies last longer if you stay in the 40% to 60% range of their output.
    5) power supplies are quieter if you stay in the 40% to 60% range of their output.
    6) Power supplies are cooler if you stay in the 40% to 60% range of their output.
  6. sir_rob
    sir_rob Limp Gawd
    135
    Jan 27, 2003
    Thanks! That really helps! Would it make any difference if I plugged the computer into a UPS and then into the Kill-A-Watt or will it always be fooled?
    What do you recommend for my next power supply (power range for a decent PSU)?
  7. Paul_Johnson
    15,993
    Aug 29, 2004
    The power meters in UPS software are just as bad. You have to spend some change before you get anywhere near an accurate power meter when your PSU has APFC.
    Depends on the system.
  8. sir_rob
    sir_rob Limp Gawd
    135
    Jan 27, 2003
    I will keep everything the same except for the CPU, RAM, and motherboard. I will go with a decent Intel quad-core, and fairly high-end motherboard, and 4 Gb RAM.
  9. Dangman
    Dangman Ninja Editor SuperMod
    46,062
    Dec 15, 2005
    So the power reading taken with the Kill-A-Watt in these articles:
    http://hardocp.com/article.html?art=MTUzMSw5LCxoZW50aHVzaWFzdA==
    http://hardocp.com/article.html?art=MTU0OSw4LCwxNjA=
    could actually be higher than expected?
  10. Paul_Johnson
    15,993
    Aug 29, 2004
  11. panfist
    panfist Gawd
    635
    May 1, 2008
    So how does one accurately measure the power consumption of their computer if not with a Kill A Watt?
  12. Dangman
    46,062
    Dec 15, 2005
    Ahh, thank you very much for the clear up.
    You need a digital power meter. IIRC, Paul as well OklahomaWolf (of jonnyguru.com) uses a Brand Electronics Digital Power meter to measure power consumptions.
  13. Paul_Johnson
    15,993
    Aug 29, 2004
    Spend a lot of money on better equipment for AC. For DC a good high quality (expensive) clampmeter.
  14. Paul_Johnson
    15,993
    Aug 29, 2004
    And an Extech Power Analyzer.
  15. Drakan290
    Drakan290 2[H]4U
    3,089
    Sep 11, 2008
    Also, don't forget. Even if you've got a 650w power supply, your computer is only taking 200 from it. It's not just 'losing' power, it's not even generating that extra 450 watts. A lot of people reccommend a higher end PS for the fact of futureproofing. i7 is a prime example, with some of their chips running at a 130w TDP.
  16. panfist
    panfist Gawd
    635
    May 1, 2008
    But shouldn't APFC error only effect power that's actually being power-factor-corrected? meaning power drawn by inducting components and the like? which wouldn't really be all that much compared to other loads in the system?
    I am probably wrong...
  17. lazers
    lazers n00b
    1
    Nov 12, 2008
    Hi, can any one recommend a good calculator out there (if any) from where i can calculate the power supply requirements of my system. Below are the specs
    Intel Q6600 Quad Core
    Corsair 2 GB Dominator (1066)
    XFX 260 GTX Black Edition
    Western Digital Sata 500 MB Hard Disk
    Currently i have a coolermaster 500W power supply and am confused if i need more or is it ok. I intend to get CM 690 nvidia edition, will the fans on the casing cause an increase in power requirements and how much.
  18. dandragonrage
    dandragonrage [H]ardForum Junkie
    8,298
    Jun 5, 2004
    Non-PFC power supplies similarly will make a cheap meter like the KaW read too high. KaW isn't all that useful for computers.
  19. Paul_Johnson
    15,993
    Aug 29, 2004
    An SMPS is a nonlinear load. A non-PFC corrected power supply will have a power factor of ~0.59 to 0.65.
  20. anonycorp
    anonycorp n00b
    47
    Nov 18, 2008
    Definitely agree with Paul[​IMG] [​IMG] [​IMG]
  21. Dangman
    46,062
    Dec 15, 2005
    Which model CM 500W PSU do you have?
