AtomicFire
- Dec 7, 2001
the two bad words that shouldn't go together!
Anyways, i'm planning on building a Mini-ITX MythTV Backend\Router box and theres a few issues that've come up.
The place where this box is sitting will have 1 coax cable connection. I need to plug 2 devies into it - a cable modem (The Linksys one, can't remember the model but its version 4) and a Hauppauge PVR-250 tuner card. I know cable modems are picky as hell in terms of the cable signal, so i'm a bit worried this will cause problems.
Our cable modem provider is BrightHouse (RoadRunner, Time Warner, whatever you want to call them) and we're getting a 10mbit\1mbit plan. I'm plannig on buying a 2-way cable amplifier designed to work with cable internet and has 2 outputs, then putting filters on the output to the TV card to filter out the Cable Modem signals and filters on the output to the Cable modem to filter out the TV signals.
The reason that i'm worried is because at my other place, I had an experience where if we used a splitter (some generic bottom-of-the-tooxbox version) to hook up a TV and a Cable Modem to the same line, then the spilitter would half the speeds the cable modem can get. Removing the splitter fixed the problem with the internet, though now we had to run a 50 foot coax cable to the TV and deal with a somewhat fuzzier picture on the TV.
Cliffs:
1. Getting cable internet + tv
2. Only have 1 plug
3. Splitter + 2-way amp + filters = good?
EDIT:
Just checked, the apartment has a junction box in a closet where the main cable line comes in, and is split by what looks like a good high-quality 5-1000MHz spilitter. However, there are markings on the outputs (5 total) where 4 are labeled "-7dB" and 1 is labeled "-3dB" - the ports have different output level? Which one is suppossed to have the stronger signal? I'm guessing the -3dB one...
Cliffs:
2. Only have 1 plug
EDIT:
