OliverQueen
- Apr 17, 2019
Has anybody tried these?
https://www.ebay.co.uk/itm/3-4-port...var=472536647589&_trksid=p2060353.m1438.l2649
The idea looks perfect but always a bit concerned when it comes to Chinese suppliers on eBay as the items either don't arrive, arrive faulty or if they do work, at a lower specification than described i.e. USB1.0 speeds from a USB3.0 port.
I do like the concept as it means that the cables are hidden directly from the PC (mine is under desk) and it fits in an existing hole in the desk meaniong it takes up no more room than the existing plastic management insert.
What were your experiences?
