tacosareveryyummy
- Jul 25, 2005
I have some rough code that I am trying to compile. It isn't immediately obvious to me what the issue is. Hopefully it's simple and someone here can help.
Here is the compile error I get..
Code:
#include<iostream>
#include<cmath>
#include<fstream>
#include<iomanip>
#include<vector>
#include<cstdlib>
using namespace std;
int poisson(double);
float expon(double);
float one_body_weight();
float rand_val(int);
int main()
int N_e=10;
int lambda=10;
int number=100;
int poi_rv=0;
int step=0;
int initial_orbital=0;
int final_orbital=0;
srand(1);
ifstream infile;
ofstream outfile;
// vector< vector<int> > C(10, vector<int>(N_e)); // Initial state
vector< vector<int> > C_prime(10, vector<int>(N_e)); //Final state
vector<int> state_vector(10);
// vector<int> n_i(10,0); // Initial state to be replicated
outfile.open("p_values.dat"); //Data file for number of steps
for(int l=0; l<N_e; l++)
poi_rv = poisson(1.0/lambda);
outfile << poi_rv;
outfile.close();
infile.open("p_values.dat");
for(int i=0; i<=N_e; i++)
infile >> step;
state_vector[0] = 1;
state_vector[1] = 0;
state_vector[2] = 0;
state_vector[3] = 0;
state_vector[4] = 0;
state_vector[5] = 0;
state_vector[6] = 0;
state_vector[7] = 0;
state_vector[8] = 0;
state_vector[9] = 0;
for(int p=0; p<=step; p++)
initial_orbital = rand()%10;
final_orbital = rand()%10;
if(state_vector[final_orbital] == 0 && state_vector[initial_orbital] != 0 ) // Orbital unoccupied then move pair to new location
state_vector[final_orbital] = state_vector[initial_orbital];
state_vector[initial_orbital] = 0;
else if(state_vector[final_orbital] != 0 && state_vector[initial_orbital] != 0) //If orbital is occupied and equal to current orbital then switch
int storage=0;
storage = state_vector[final_orbital];
state_vector[initial_orbital] = storage;
else //Do nothing
continue;
for(int q=0; q<10; q++)
state_vector[q] = one_body_weight()*state_vector[q]*one_body_weight();
for(int m=0; m<=10;m++)
C_prime[N_e,m] = state_vector.at(m);
return 0;
float expon(double x) //Generates exponentially distributed random numbers
double z=0;
double exp_value=0;
do
z= rand_val(0);
}while ((z==0 || z==1));
exp_value = -x*log(z);
return exp_value;
float rand_val(int seed)
const long a = 16807; // Multiplier
const long m = 2147483647; // Modulus
const long q = 127773; // m div a
const long r = 2836; // m mod a
static long x; // Random int value
long x_div_q; // x divided by q
long x_mod_q; // x modulo q
long x_new; // New x value
// Set the seed if argument is non-zero and then return zero
if (seed > 0)
x = seed;
return(0.0);
// RNG using integer arithmetic
x_div_q = x / q;
x_mod_q = x % q;
x_new = (a * x_mod_q) - (r * x_div_q);
if (x_new > 0)
x = x_new;
else
x = x_new + m;
// Return a random value between 0.0 and 1.0
return((double) x / m);
int poisson(double x) // Poisson distribution for number of steps
int poi_value=0;
double t_sum=0.0;
while(1)
t_sum = t_sum + expon(x);
if (t_sum >= 1.0) break;
poi_value++;
return poi_value;
float one_body_weight() //Weight w for one body part of the hamiltonian
float E_1;
E_1 = exp(0); // Currently set to 1.
return E_1;
Code:
mal@ubuntu:~/research$ g++ csmc.cc
csmc.cc: In function ‘int main()’:
csmc.cc:94: error: no match for ‘operator=’ in ‘C_prime.std::vector<_Tp, _Alloc>::operator[] [with _Tp = std::vector<int, std::allocator<int> >, _Alloc = std::allocator<std::vector<int, std::allocator<int> > >](((long unsigned int)m)) = state_vector.std::vector<_Tp, _Alloc>::at [with _Tp = int, _Alloc = std::allocator<int>](((long unsigned int)m))’
/usr/include/c++/4.4/bits/vector.tcc:156: note: candidates are: std::vector<_Tp, _Alloc>& std::vector<_Tp, _Alloc>::operator=(const std::vector<_Tp, _Alloc>&) [with _Tp = int, _Alloc = std::allocator<int>]
